how's that coming ? .... looked a bit of a 'mareThe landscaping on one I'm working on is around 250k with added radiation![]()
Well from when I last posted pictures we finally got to the drive to sort out once reducing everything to 300mm below found original drive built on topsoil so had to remove it all as it ended up from not far from formation level and took it down 1.6m below in certain areas to make sure the landscaper was happy it wasn't going to sink so by Friday we got drive back to where we started and contamination membrane layed at 300mm below finish level then put on 150mm of type 1 leaving 150mm for 100mm concrete and 50mm limestone sets to be layedhow's that coming ? .... looked a bit of a 'mare
That explains the Cornish thenCopper
Tin
Zinc
Arsenic
Lead
Iron
Silver
Uranium
Wolfram
And a whole host of sulphides that make acidic water
But other than that everything is peachy![]()
It will get Glowing reviews when finished.how's that coming ? .... looked a bit of a 'mare
What's the map referencing as that's missing
Radon.What's the map referencing as that's missing![]()
Well. That's one thing we ain't gotRadon.
Ah yeah real short half life that stuff that's why we have uranium just lying aroundRadon.
There's more pitchblende loads in the ground than you would realise. One at the back of ashburton from memory. Quite scary when you realise how easy it is to find radioactive material.Radon.
Kept me busy last weekRadon.
got some lovely looking digging there DoobBit of landscaping. The Sherpa is a landscapers best friend, especially on tight jobs. View attachment 37962
Replacing the UJ in situ?Same s**t different day
New prop shaft ordered, old one disintegrated todayReplacing the UJ in situ?
could've been worse ... could've been the front end droppedReplacing the UJ in situ?
