Grahams
Maybe 18Ill help you ....17 mpg ?![]()
Maybe 12….Maybe 18
I am frightened to ask what weight that all is!!Just done a 1200 mile trip with the new trailers. All performing well.
You didI am frightened to ask what weight that all is!!
Looks heavy on the tow bar from photo. Appearances can be deceiving but looks like 1200 miles would be a long old haul.I am frightened to ask what weight that all is!!
Just under the 3500kg mark, depending on what attchments I'm carrying.I am frightened to ask what weight that all is!!
Most modern pickups are on their arse with any sort of loadLooks heavy on the tow bar from photo. Appearances can be deceiving but looks like 1200 miles would be a long old haul.
It is reasonably well balanced. The back of the Ranger always squats a bit, always has.Looks heavy on the tow bar from photo. Appearances can be deceiving but looks like 1200 miles would be a long old haul.
If like mine, and its got a factory fitted towbar, they are high and you end up going a little heavy to keep the trailer somewhere levelish.Looks heavy on the tow bar from photo. Appearances can be deceiving but looks like 1200 miles would be a long old haul.
That’s down my way. First glance looks good but can’t have much reach as doesn’t look like any stabilisers.bet the drawbar, etc., groans on this ... the jockey certainly is ..... God only knows what the nose weight is ??
www.facebook.com
the legs're pinned on BTLsThat’s down my way. First glance looks good but can’t have much reach as doesn’t look like any stabilisers.
Look to be fixed so must limit reach? But yes you're right there are legs!the legs're pinned on BTLs
If you had a gooseneck /5th wheel tipping version then you could have a load capacity of about 3500kg I should think. Enough for 3t with Tilty and buckets, and then a decent mobile muck away wagon. All on a B+E license![]()
1.5K views · 8.1K reactions | Johann Tischler on Reels
www.facebook.com
no idea of a load capacity (not much I doubt?) .. neat but pretty impractical
View attachment 79432 View attachment 79433
