Do you have to use Chinese bolts for this method to work?or weld a plate to the rod - tap a couple of holes and screw it off .... sorry it's a bit rough
well they'd want to be their best quality bolts for sureDo you have to use Chinese bolts for this method to work?
aye that might do the trick ... wanna be a bloody good 'condom' fit though ... same trick for getting a spigot bearing out the back end of a crankshaft .. whether it'll have enough volume is the only questionable thingI'd be finding a fitting to screw in that would take a tight fitting high strength pin (could be a blanking plug drilled to take the plain shank of say a 10 mm ht bolt)
Fill the body with grease or thick oil (heat may be needed to get rid of the air) ,push pin in and whack bolt head with a sledge hammer. Assuming that you're got the air out and you have a reasonable fit on the pin the resulting force is really quite large ......very very quite large![]()
