C
ChrisP
Hi All,
I was using my mini digger today (Kubota K008S) and the track came off. I got it back on, grabbed the grease gun and started to re-tension. However the grease pressure built but the idler wheel did not tension. I have check the grease nipples and all seems to be working fine. I have taken the idler wheel off and I believe the piston / ram is completely jammed. I have looked online for a new piston ram and block, but cannot seem to find anything. Does any one have any ideas how I can get the piston pin out?
I really hope someone can help as I am at a bit of a dead end. Suggestions welcome.
See photos attached of the jammed piston.
Thanks, Chris
Thanks, Chris
