Mogmans creations 🤔
Acquired this today should of taken a picture of it all but it’s a oxy cutter on rails but can’t find any information on it
any one seen one @V8Druid 🤔
just googled it and there’s one on eBay at the moment so stuck a cheeky bid on it👍 Plus I’m going to Swansea on Monday to drop some gear off so hopefully if I win it I can collect on my way home😉
im sure I can make something out of two of them🤔😂😂
I think its the same as my mate has got :unsure:
He makes templates out of tin 10mm or 3/8" smaller than than your finished item, a little wheel that`s magnetized follows around the edge of the template and transfers the shape to the torch.
that's it ... follows a template much like a pantographic version, 'cept it's motorised not manual .. the speed controller varies the drive wheel speed around the template ... everything (the X & Y axes) needs to glide smoothly
i'd guess that'll be yours Mog .... can't see many folk chasing that
Hope so🤔 it’s a step up from burning free hand😳
Is it though? From what I’ve seen, you’re a dab hand with the torch. And you’ve got to spend the time to make the template.
I guess if you are making multiple of something then it might be worth the time?
Have you got a production run of something to use it for?
Yes🤔 I have swapped from matbro pin and cone to manitou so need to convert about 10 attachments plus any more I build/convert
I costs about £150-200 for a set of brackets and I have steel plates coming out of my ears😂 so home grown for me, I’ve made a template that I cut around that works well but would be fun to piss about with a new toy plus I can put a picture of it in the ‘what I bought today‘ thread😂😂
used to have a little magic eye profiler, would do IIRC about 750 x 450 components ... was good once set up but getting the drawing 'acceptable' for the lil' sod was a work of art ...... 1mm Rotring draught'sman's pen on drawing paper/parchment was the best I found for a good neat black line for it to follow .... was very accurate once you'd got the suss on it.
yes and no .... still got to make the templates
I see what your saying but if making Say a set of bucket brackets that have to match you only make one template and because it’s made from something like 2mm plate can cut on my hand shear and rub up on the linisher my biggest problem is holding the burner square to the job when going around corners doable but takes concentration (which I seem to run out of half way around😳😂😂)
we‘ll see what happens if I don’t get on with it I could just sell it to you and you could paint it😂😂😂😂
yeh for multiples they're damned good ... the faff of making every template 10mm, or whatever it is, smaller/bigger if an internal is a right PITA though :(
Made an extension for the 3 meter body🤔 made from half a folding tail lift so when not in use it folds forward and lays flat on the body👍
just so I could get my telehandler on with the big man basket
even made a light bar for it too
then had to reverse up this ally way
How’s HMS Britannia looking now?!
Not done much with it 😢 I think I’m waiting for the arse to fall out of the scrap job🤔😂
need to get on with it but it’s got 18” of concrete in the bottom of the hull🙄 but managed to acquire a big breaker for my 18 tonner😉 as the burner is struggling with cutting concrete 🤷
View attachment 37124Not done much with it 😢 I think I’m waiting for the arse to fall out of the scrap job🤔😂
No wonder it was heavy!!!!
(Looks like you’ve been in my manor, hope you stopped for an ice cream!)
