well that's very astute Rory .... it was going to get a louvre panel in front of the mesh ..... but self closing :unsure: ... there's a thought :giggle: .. almost an easier build than a fixed louvre :cool::love: ...... any other bright ideas (y) :giggle:
this does NOT fit into the bright ideas category LLo_O :censored: .... third word is OFF!! .... and when you get there ... keep going!! :p:ROFLMAO:
I was thinking of your neighbours 😂
bobthebuilder
I've reached the conclusion it's the speaker volume button ... if I touch it / reset it, I have all sounds back ... seems to 'die' in my pocket :unsure: ... must give it a good blow out with the air line
a tip hoover your phone ,do not blow it too hard with airline ,you drive the dust in further
A
AusDave
and that's why I posed the Q Mog ... yes 170ltr by my calculation, so a lot of oil and with your experience of a similar set up that's good to hear ... reassuring (y):cool:
170 litres!! What activity is going to heat that amount of oil and how long will it take to do so non stop :confused:
Put some alloy fins on the tank or use an inline finned type of passive cooler.
Adding additional electrical sensors, controls and wiring just adds unnecessary complexity which is the problem with so many items of heavy equipment nowadays.
Keep it simple, if it needs any additional cooling at all, a passive solution should be enough. Stick it in the radiator fan airflow if you really think you'll get enough heat. Oh and you can always paint some shiny tish on it :)
Hi Dave ... have you not seen the cooler that came with this package of bits?
It was plumbed into the system before so assumed it'd be a good idea to include it again :unsure: ;) ..... WP_20220429_16_23_27_Pro.jpg WP_20220429_17_28_14_Pro.jpgWP_20220512_14_12_45_Pro.jpg WP_20220512_17_09_37_Pro.jpg WP_20220512_17_09_30_Pro.jpg
there's a fair VD pump on the arse end of this Deutz :oops: and is gonna be pushing some oil around
still researching how to plumb it for load sensing, if anyone wants to chip in :giggle:
Canal Navvy
Canal Navvy
With that amount of cooling you'd think it was intended to operate on a desert airfield in combat conditions 🤔
Who knows ..it may come in handy when it's pressed into action on the plantalk recovery team 😎😎 armoury is coming together nicely with Rory's additions now 👏
well not quite ... Mog said it was off a de-icing truck from the air port .. ran the boom and pumps for the de-icing fluid
Yes ran all the boom functions plus 2 big pumps to squirt the juice and a couple of motors that ran two big fans that heated the juice up👍
how the hell does a fan heat the juice up Mog????? :unsure::unsure:
That cooling fan looks identical to one I've got strapped on side of the little lorry for its auto box. So far I've never seen it come on. On later models they seem to have 2 smaller fans.
You need the proper valve bank to get load sensing like the pveu type or else you're gonna need a lot of shuttle valves to get load sensing to work
Are you planning manual levers, solenoid or proportional valves. Or hydraulic pilot
Manual levers Mike .... no point in over-complicating it :giggle: .... LS can be done mechanically with balanced orifices, from what I read :unsure:
Have you already got the spool block?
I’ve had to do both standard valve with taking a 1/4” sensing line from each service back to the pump with a mess of shuttle valves and the proper load sensing valve block with single load sens line back to pump. Always been kawasaki pumps up the valves have been danfoss.
