Hydraulic 46 varies from £300 a drum to over a grand! I normally just use whatever the local tractor dealer has branded up. What do you guys use?
you know my thoughts on engine oil ... Shell Rimula - X, nothing but for decades, or whatever the X has become now - can't recall, but got a couple of 20s here ... don't need drum quantities any more ...Hydraulic 46 varies from £300 a drum to over a grand! I normally just use whatever the local tractor dealer has branded up. What do you guys use?
In theory what you need to buy for the most modern emissions engine should be ok in the rest provided its within grade range.I’m just about out of engine oil for all varying machines, really need to find one oil which will do everything.. 4 different brands of machine/engine may not work out as simple as i think? I guess over spec on the smaller ones won’t hurt..
winner thenBut all the hydraulic oils say they have anti wear, anti foam, anti everything additives!
That's why I run Bobcat. Self changing.The biggest false economy is skimping on filter and oil changes. When you drop the oil out of the tank, you only change between 20 and 50% of the total system capacity, depending on the machine.
