Hi I have been in touch with Paul regarding his PM. Regarding the 'Dipper Wheel' this has been done, it is called a 'motorization castor' & can be seen here
http://www.oilyhands.co.uk/images/Benny/Benny_4S_brochure.pdf Also the Kamo Junior 'true spider' had this as an option among others.
It is a bit more complex than than it might first appear because of two problems. 1) Vacuum cavitation when the vehicle is wanting to go faster downhill than it would be powered on the flat by the oil flow from the engine revs setting (overrunning)
2) momentary pressure spikes caused by an incautious operator suddenly dropping the spool lever.
Many motors have anti vac valves built in to the motor seal drain system, & a cross line relief valve can iron out the spikes - the downside to this is loss of 'trapped fluid' braking when the CLRV operates. The larger Struck Corp older machines had positive manual back up brakes for this event.
The above is a classic problem when running a motor on a ram spool - using the trapped fluid as a holding device. Many designs have been short lived including a kit/plan machine called the Cadplans 841 - the above prob destroyed its motors on non flat land & also appeared in their Cadtrac tractor.
Some motor types are more prone to this than others.
It is not a problem with motors on motor spools as these spools are open to neutral when closed so cannot develop vac or pressure when resting BUT the motors have to contain fail safe in built brakes taken off by a shuttle valve - otherwise the motor would just be free running when not under power.
The first set up is found on the little French kit machines, hence they are not recommended to be used on a down slope greater than 10 degrees. - They could have an added Lossi brake, shuttle valve, & motor spools to get round this. The engine they use can cope with 25 degrees in any plane.
It is also a reservation I have on the budget ' Carter' machines
It has been said that the Powerfab 360WD was prone to run away when parked on slopes as it got older - see Machine Builders Network
I would not sell the Gopher as I wish to see it run one day. Sadly my Father is very frail & ill just now, but I hope to make a little more progress when I can get time on the project. I will be interested to see the machine that Paul has bought. Personally I think the 'powered wheel' thing on such a small machine is overstated - there is nearly always a little dumper on site for the digger to load - this can tow the 'Powerfab' over longer site distances. It was just chance that mine mine had these, all the ones i drove in the past did not. You can drop the bucket into the dumper for it to quickly make short hops.
