Wanted Chipper
4k and she's yours 🙂
Russell
thats more like it but with one more cylinder
Gave 1k€ for that a few years ago ... wanted an electric start on it really but hard to warrant as it only gets used couple of times a year - I made up a simple hitch affair so I can tow it with tracked dumper and chip into it if needs be.... fairly capable thing ... hydraulique feed and will do 7cm kinda stuff if you help it a bit and let it get its breath back.
Edit: not really doing it justice.... will do more like 10cm if your kind.
thats what I really want but I dont got the cash.
maybe next year:)🤞
Good little machines those - commanding strong money but that might start to change now the towing restrictions have been lifted possibly…
Get twin-feed rollers (like the one in the ad) as they are a lot better than the singles.
Maxus
A bit different but very good machines. Blades take a lot of abuse and less prone to blockage when chipping/shredding material such as wet leylandii. Will handle green waste. I think they're good to 100mm diameter branches. Be interesting to see what it goes for, 4k would be a steal.
I have seen the little chippers but thought they might struggle with stuff like leylandii so wanted a balance between capability,overall size and price. I like the look of the timber wolf tw125 but they look to sell for a bit more than I want to spend.
As for ,do I have enough work for one, I can see it earning me more than anything else would currently . A bigger digger and dumper would probably earn more but would need to rent a yard and they cost a lot more that an old chipper.
Also I can hire diggers and dumpers for not a lot but I'm not sure if I can hire a chipper on the island and if I can it will be £120-£140 a day.
I'm hoping to be able to move it with my 500kg dumper. I know that can move my trailer and that's 660kg but don't want to push my luck with a 1500kg chipper.
The little drum chippers actually work best on straight stuff like Leylandii- so long as the blade/anvil gap is set right to stop it choking itself on the needles at the end of the branch. Where they struggle is thorny or brashy stuff, that's where a towable machine with feed rollers comes in.
Maxus
You'd have to be a bit mental or have deep pockets to buy one new @ 15,700 ex vat.
I have the one down from this, it's been very good as a landscaping tool. Has hydraulic drive on wheels so is maneuverable and easy to load onto a trailer with ramps. An upgrade from a drum chipper that was also very good for the money but fussy about what went through it and hardwork feeding without hydraulic rollers.
Wow 16k new
Fms1
Fms1
Saw this on facelessbook, that the size you’re after?
Maxus
There’s no way that’s worth it. Eliet have just survived by being machine of choice for councils etc.
That maybe true, but the timber wolf equivalent can't process green waste with bits of soil/small stones or old fence panels with nails in, and is not self propelled. You can also sharpen the blades on an eliet with a 4" grinder on the machine. I had a quick look, 16k doesn't get you much chipper these days new.
Those Eliet machines are shredders, not chippers. They can handle mildly contaminated material (chippers can’t, you have to feed clean material only into them as they essentially have two knives cutting against each other and therefore must be sharp to work).
Shredders are far more power-hungry than chippers though, and don’t create as nice a product. A 13hp shredder won’t be anywhere near as productive as a 13hp chipper.
I don’t know of any tree cutters who use shredders…
