Wanted 4x4
Is there no chance of finding a good independent mechanic? Dealer mechanics are not what they used to be, they are probably not used to dealing with vehicles more than a few years old and just do routine servicing.
Might be worth getting it looked at by someone else and keeping it going? Sometimes better the devil you know.......
most main dealer mechanics are box fitters these days .. take a new part out the box and fit it ... if that don't work try another box :mad::mad:
you need an independent small guy for any chance of a true 'diagnostic' mechanic ... one that can think and reason his way through a problem :rolleyes:
Russell
I have thought about fixing but it's minimum £450 for second hand parts and code reset before I even at look the coolant problem. The other annoying thing is only a mut2 code reader will work (£1000) and the local independent I use for mot don't have that one. Those ssanyongs look like they could be just the thing for now and then get a ranger in a couple years if I don't find a rot free 80 series land cruiser.(y)
Delphi can also do near enough all of the things mut can do. There is cheap versions on eBay when I had my l200 used it to reset scv and steering settings.
If it's nothing more complex than reading codes most generic code reader apps and a cheap obd tool will do the job.
Not sure what age yours is but
http://faq.out-club.ru/download/pajero_iv/maintenance/Service_Manual_2007/2007/index_M1.htm
Is the service manual if it's not the correct year if you cut it down to the .ru you will find alot of mitsubishi manuals. Came in handy when I did the carbon decoke of the inlet manifold on my l200
Russell
The Touareg turned out to be rubbish but luckily a discovery td5 came up locally for £800 so I got that. Fingers crossed it lasts long enough to for me to fix the shogun.
Td5 can be a decent vehicle, what was up with the touareg?
Russell
They said the air suspension was stuck on max height so I said I'll leave it. Was £3000 with 80,000 miles
Russell
Abs related wiring/abs ECU fault and possible head gasket. I hope it won't be to hard to fix because it's 10 times better than this disco.
Powerfab
Powerfab
Are you sure the ABS is wiring related? The Shogun had a very common fault on ABS due to the sensors at the wheels. It read against a castellated ring sitting directly on the hub carrier behind the disc. This was prone to rusting and/or splitting which then threw up ABS errors. Replacement ABS sensor rings are available, if IRCC you need heat to remove the old and to make a shrinkage fit with the new ones.
Russell
The error codes are abs pump and accumulator fault. Replaced the hole master cylinder/pump/accumulator unit and cleared the error codes. Went for test drive , hit a small bump and abs light came back on.
Russell
I've got a code reader coming so I hope that can reset the light. My plan is to find the abs ECU and stick new cables in for the offending circuits and see what that does. If my code reader can't reset it I'll get a ECU as well. Once that's done i need to figure out if the head gasket has gone or not. The water went brown and the rad cap went crusty. I don't know if gearbox oil mixing with water would make it do that ? I also need to see if there is a engine oil/water heat exchanger in there. Its definitely not the egr cooler. With the limited driving I have done since, the water has stayed clean but it's still loosing it.
I thought about weighing it in but everything else is tight and good and it's got minimal rot. With a bit of titivating the body would probably do another 10years.
Also newer 4x4s are currently £570 a year on tax so that limits you to newer £15,000+ pickups if you want to tow.
Oil from head gasket tends to turn the coolant like mayo rather than brown, could just be something as simple as wrong/mixed antifreeze and rust from in engine. Try a coolant drain and change genuine mitsi coolant is expensive but I'm sure I've still got around 4l in the garage if your nearby to Northampton, although you'll still probably need a litre or two. Otherwise not too sure what coolant is compatible with it.
abs faults tend to be more wheel sensors or wiring near wheels
Russell
Thanks for the offer but I'm on the isle of Wight. Need to pressure test coolant system and see what happens
Has it been run hot? Or would you say it runs hot normally?
On one of my Shoguns there was a horrible brown sludge in the engine/rad, turned out that the impeller had disintegrated on the water pump! So it wasn’t circulating properly. I never used it before sorting the engine out, but it must have run hot before I had it.
This was an older model, and a 3.5 petrol, but similar symptoms?
tinydigger
tinydigger
not the same make but on my old Vauxhall frontira it kept over heating and blowing water out of the header tank took it to my garage and they did a pressure test and it come back head was gone. They where just bout to start stripping it down when one of them remembered that the water pump on them where known for shitting the impeller like shovel hands shogun did so might be worth a look at that before you strip the head
Russell
I'll look in to that. I've never seen it go above half way on the temperature gauge but I did notice a different smell recently, almost a shitty smell but that could be un related. I towed a car on a trailer the other day and the temperature didn't go high then. My local garage that cleared the error codes the second time did a sniffer test on coolant after I flushed it and said it could be starting to go or could be residual s**t in the water, not a strong result/colour Change but still a change.
