not the same make but on my old Vauxhall frontira it kept over heating and blowing water out of the header tank took it to my garage and they did a pressure test and it come back head was gone. They where just bout to start stripping it down when one of them remembered that the water pump on them where known for shitting the impeller like shovel hands shogun did so might be worth a look at that before you strip the head
Rory had a similar issue with a truck a while ago and told him to check the water pump for flow .. impeller was letting go on the shaft when it was getting warm and then she was getting hot due to bad circulation ... I've seen it before, hence pointing him at it ... well worth looking at
@Russell ... as for coolant looking ropey ... it does degrade over time and accumulates crap from the system ..... as said a bloody good flush wouldn't hurt it ... then put a system flush in it for a few miles .... then run it with a constant hose feeding the system ... with the thermo out and hose in the housing to really purge the block - bottom hose off and restricted a little .... flush rad separately
