Ultimate iveco setup 👍
Appreciate it’s 7.5 ton but cracking setup for multi use jobs which he seems to use it for
I don't know about the trailer or max train weight but those 7.2t ivecos carry about 1.5t more than a 7.5t lorry and plenty over here run those as hookloaders
Just looked up to 4.9t less the body configuration.
Only issue then aren't you limited to about 1t trailer capacity without the correct licences?
Only if you are using grandfather rights.
By now I would think the majority are using proper licenses
If I had to do a licence have up to 7.5t as I'm mature😀 but if I did new licences I think I'd buy bigger
750kg for the trailer
a hook lift gear and body'll bring that down to around 3t then ... my old Iveco'd do 3550kgs, plus another 150kgs with the sideboards and tail off it .. 21ft keruing bed
Our old Merc atego 7.5tonner weighed in at 5.1 ton in her running clothes. Could get 7.6 M lengths of hollow sections in the back which was handy. Often had 4 ton in her 😶
that little Iveco went better with fully loaded bed and 3.5t behind her than she did empty ... was a great truck TBF (y) (aside from the stupid metric wheels - rad. was about 6" off the floor :mad: and had to watch where you went :rolleyes:)
My old 7.5t hook loader was great but couldn’t carry enough to be properly useful ....i know that one posted up should carry a bit more but still not enough for it to make life really easier, the 19t hook im running now has 5m skip and a swb and it works fine on domestic jobs, not any different to the 7.5t in reality ,never not got it in yet and carries 11t ish - enough to make your life much easier.
