will see if I can find you some more pix O.O. .. must have some somewhereThe oilyhands site owner has restored what was then a Fleming Micron, Fleming & Gopher International joined forces to become Manor, Both models were built until the end when Powerfab bought up all rights & were the last man standing in UK towables.
Thanks for the pic, Mr Druid, I take it that the plug in wheels form an unbraked sprung axle? Ideal for longer tows. Mine has to go a couple of miles to a mate for storage for now. I will be hopefully soon able to do what you did & buy a sort of retirement bungalow or similar with sheds / containers / workshop but do not want to jinx anything. I have no plans to retire but keep working in a small way. Does your Manor have wheel motors - some did.
I gather the Rexroth wheel motors & 60mm bore 13'' rams were common to both the Micron & 5 Star.
It looks bigger than I imagined, I remember your thread on restoring it, have you had much of a chance to progress any with it?yes that is the actual machine, thanks Craig. It was before the Twose slewing gear was bodged on because the original slew post failed (I built another).
I bought it off a Mr John Cooper of Oxford (he pops up in the prog) It had been standing 11 years in a garage & was going to be scrapped. There had been some plan to convert it to pulling a single furrow plough on an allotment - but he never did it after he retired.
The Micron has a more sensible dipper length, but the above would be ideal for ditch cleaning? Each front leg can swing through an arc to be pinned as the job in hand needs. The brackets to take a centre axle can be seen between the front & back wheels
Bit of info on the project here in case you have not seen it
Gopher 5 Star Digger Restoration
I am restoring this, the slew system had failed, & an old Twose backhoe slew system was added by past owner. This moved the Kingpost 21'' forward & added much weight putting it off balance, so could hardly keep rear wheels on the ground. I have built a new slew post & built up the fixed slew...www.planttalk.co.uk
what does that trailer weigh though??So this is my idea of a trailer and towing wagon. View attachment 68145View attachment 68146View attachment 68147
Dont care.... looks good drive her onwhat does that trailer weigh though??
@doobin’s 10 ton 8 tonner would look well on there - perfect setup to get s**t done!!!So this is my idea of a trailer and towing wagon. View attachment 68145View attachment 68146View attachment 68147
the front legs have detachable 'rousters' on the feet - also considered making it some spiked feet too ... just have to be aware of their limitations, depending on the surface, but in grass/soft stuff, they hold fairly well .. the rear leg/blade also gives a decent hold tooMr Druid do you find the lack of a front blade to dig against with the Micron a hindrance? sometimes called 'dustpan ability' My former apprentice was somewhat scathing about my idea of ever hiring it out - saying more of a collector's piece - admittidley things have moved on.
Yeah still got the old girl MOT due Thursday hopefully makes another oneHad a few, and still got one tows 3.5t no problem.
I think @Left hooker has one as well?
Re visiting all this, Yeti still poss for a smaller machine as will tow 2t, Tiguan as Pettsy says up to 2.5t Another towing site not really plant related suggested the Mitsubishi Shogun SWB (will tow 3t) as a good option as against the Yeti. Many of these automatic (wet torque converter) I have no experience of driving automatics (unless you count a 3CX) & fear cost of it going wrong. Up side seems to be that a torque converter might pull a heavy load well. All of these are available in the used market - some low mileage. As to Defenders once they stopped making them used price just rocketed, & most high mileage. Anyone know what that INEOS 4wd is based on - has he bought some tooling from another maker - could never afford the thing though. Was looking to run a 1t digger but trying to get into small scale crushing needs a bigger machine really to carry the bucket.I never get this 85% rule caravanners go on about (is only advisory) Defender 90 about 1.7t empty yet will tow 3.5t. Granted there is much wind load on a caravan that is not on a digger - compact load lower C of G.
It would probably fit on 450s!@doobin’s 10 ton 8 tonner would look well on there - perfect setup to get s**t done!!!
Just get a truck that will tow 3.5t and be done with it. Isuzu rodeo is a sensible motor for your kind of thing.Re visiting all this, Yeti still poss for a smaller machine as will tow 2t, Tiguan as Pettsy says up to 2.5t Another towing site not really plant related suggested the Mitsubishi Shogun SWB (will tow 3t) as a good option as against the Yeti. Many of these automatic (wet torque converter) I have no experience of driving automatics (unless you count a 3CX) & fear cost of it going wrong. Up side seems to be that a torque converter might pull a heavy load well. All of these are available in the used market - some low mileage. As to Defenders once they stopped making them used price just rocketed, & most high mileage. Anyone know what that INEOS 4wd is based on - has he bought some tooling from another maker - could never afford the thing though. Was looking to run a 1t digger but trying to get into small scale crushing needs a bigger machine really to carry the bucket.I never get this 85% rule caravanners go on about (is only advisory) Defender 90 about 1.7t empty yet will tow 3.5t. Granted there is much wind load on a caravan that is not on a digger - compact load lower C of G.
Ineos built from scratch but uses some parts already availableRe visiting all this, Yeti still poss for a smaller machine as will tow 2t, Tiguan as Pettsy says up to 2.5t Another towing site not really plant related suggested the Mitsubishi Shogun SWB (will tow 3t) as a good option as against the Yeti. Many of these automatic (wet torque converter) I have no experience of driving automatics (unless you count a 3CX) & fear cost of it going wrong. Up side seems to be that a torque converter might pull a heavy load well. All of these are available in the used market - some low mileage. As to Defenders once they stopped making them used price just rocketed, & most high mileage. Anyone know what that INEOS 4wd is based on - has he bought some tooling from another maker - could never afford the thing though. Was looking to run a 1t digger but trying to get into small scale crushing needs a bigger machine really to carry the bucket.I never get this 85% rule caravanners go on about (is only advisory) Defender 90 about 1.7t empty yet will tow 3.5t. Granted there is much wind load on a caravan that is not on a digger - compact load lower C of G.
I think they may have possibly borrowed some ideas from another similar looking vehicle though...Ineos built from scratch but uses some parts already available
Zf gearbox, so pretty much a BMW engine and the gearboxes, according to their info they run a "heavy duty" torque converter and a low and high range box. The heavy duty torque converter is probably just a standard version off one of bmws more powerful dieselsIneos built from scratch but uses some parts already available
A customer has "them" ...Zf gearbox, so pretty much a BMW engine and the gearboxes, according to their info they run a "heavy duty" torque converter and a low and high range box. The heavy duty torque converter is probably just a standard version off one of bmws more powerful diesels
