RavedenBrook
Better off hiring a proper diesel/petrol, hi tip tracked dumper, when your doing the bulk work, can't see those electric ones with a 2hr max runtime being up to the task, especially with a 6-8 hour charge time.
If your doing alot of digging work or bulk removal for your project if you need to load a skip those dumpers in the original post won't be of any use.
likewise won't be much use for stockpiling for a grab either, as the low ground clearance when tipping means you'll need to build a ramp up as you stockpile the material which then brings the biggest issue of once it's on an incline you won't be able to tip a full load as they look like manual tip.
For moving the odd bit of stuff around they are probably great but you can hire a proper diesel/petrol hi tip for less than £200 a week
Cheers @Brendan
I think we'll have a proper machine when excavating etc.. Though there are some parts of the plot pretty much only accessible via a wheelbarrow, up slopes, where we're going to be depositing quite a bit of topsoil (trying to keep as much on site as we can), this is where I see the mini dumper coming into its own. It'll take a while granted, but less exhausting than manual barrowing.
