So, I've bought a used EC02 4-pipe model with S30-180 top and bottom.
I will be buying S30 hitches to fit my current machines, E27 and E19. The E27 has steel tracks and extra counterweight. The E19 is set up with the short dipper option and extra counterwight. So both as good as it gets for tiltrotator operations. I know the top hitch won't be ideal on the E19 but it's the way I want to go in order to share it between the two. I also want to be able to drop the tiltrotator off easily for bulking out, ripper, breaker and grab work. I will be keeping my existing grab/rotator combo for now as it works well, although I think the EC02 has throughports for a grab function.
Given the above, which bucket sizes would you recommend I purchase? Which buckets should I most definitely buy as Scandi spec buckets (and from which manufacturer) and which would be OK to use my existing buckets with a weld on plate? Specifically, which litres and widths for the machine specs as outlined above?
