Johnny
Yes. Hopefully a good outcome.
I will keep you updated. Could be a few weeks
is the solenoid on top of the shuttle working when you energise the reverse function ? ... my switch can be a PITA when stood for a while ... contacts presumably oxidise .... ... check you have voltage at the solenoid ... if so take the solenoid coil off, energise it and put a screw diver or similar metallic (magnetic) object in the bore - you should feel it grab ... if it does it could be the armature in the valve stuck or bigger issuesAny suggestions what my problem could be on same dumper. Not getting any drive when putting shuttle in reverse. Forward working fine, its not shuttle switch and we have changed trans oil and filter. Thanks.
On mine, the relays can play up. There are 3 of them behind dashboard. Try swapping them around and spray plenty wd40 on contacts.Any suggestions what my problem could be on same dumper. Not getting any drive when putting shuttle in reverse. Forward working fine, its not shuttle switch and we have changed trans oil and filter. Thanks.
Hi Johnny I came to the forum looking to learn about shuttle forward and reverse problems. It brought me to your post and I now realise I have similar brake problem with Dot 4 having been used, Would you be kind enough to tell me what fluid you used and what was involved in the refurbishment?Hi
I have a 6 ton thwaites all drive dumper 1998 and it’s been lying a few years. Dot 4 brake fluid was put in instead of mineral fluid and swelled the brake seals. I recently pulled it out and took skip off and power washed it and put into shed.
It has got a brakes sorted, full service, niggly electrical problems etc., all sorted. I took it out of shed today for a drive and very quickly it started to put a pull on the engine. I got it back into shed and took bottom prop shaft up. Jacked it up at front and lifted back end with forks. I started it up again and transmission is tightening up and the housing was starting to warm up. Also it appears to be trying to blow the transmission dip stick out. Checked hand brake as I put on new pads and it is running free. Has anyone any ideas
Cheers Mick thank you, oil levels are good. haven't checked the oil cooler. Will do that.Check all your oil levels, and the gearbox oil cooler, follow hoses from box back down the near side to radiator.
Hopping to have a known working handle to try a little later in the day. I'll post how I get onJCB telehandlers of that era had a diode inside the wiring loom that couldn't be seen and wasted lots of time the first time you came across it![]()
