Anyone run a flail mower / topper on one?
The place I use to work had one on the big 8 series for doing central reservations.
It was ok.
If you have the Avant already and want to cut a little bit of rough grass then it's perfect. If you are buying an Avant to use a flail there are far better weapons. Likewise if you want to do a big area.
Even with the float built into the headstock they don't follow the ground brilliantly because of the lack of centre pivot or rocking axle.
And because they are hydraulic they are not the most efficient use of engine power.
They could also really do with hydraulic offset as the genuine Avant flail doesn't allow you to get massively close to fences.
And in am open cab in summer you get to sit in a plume of dust.
