Sorry, but having one of your bag lifters will move the centre of gravity forward. Much safer to have all the loops on the one hook as designed even if you have to use a short strop to achieve this with over full bags.
sorry - disagree .... you are still lifting in the centre of the bag/mass as you would with all the straps on one hook, but not running the risk of bursting the bag ... only mod would be to have the lift eye on the lifter rotated 45 deg.s to align the lift eye across the sides of the bag rather than the corners to sit on the hook squarely
Spurry
My wife decided that the three-compartment compost bins were no longer needed, so they had to be removed.
Not sure if I put enough contrete on the uprights though.:rolleyes:
Jimoz
Yes, they make a huge difference. Where all the loops are on the one hook (even if you use a short strop to achieve this if the bags are very full) the centre of gravity is bought back closer to the machine and is lower as the boom is right down compared to suspending the bag on forks.
I had a fixed version, but the adjustable is much better, although a little heavier.
Do you get the bags with the 2 sleeves down the side for forks? We get some of them with certain merchants.
Bag lifter on mine...ready for tomorrow's outing
Doing a favour for engineer we do a lot of work for and who’s done all my extension stuff for free, can you expand gateway.
I’m like easy enough, next thing 1.5m across 1 ton ish sycamore stump in way and against the dry stone wall
Got it out after 2 hours digging rd it and teasing it up working toothed bucket under to fulcrum on it
Stupidly mentioned I could terrace field in 2 days with 3 ton now expecting that doing as well, becoming an expensive engineering package with the oak gate he specified not softwood
Does anyone still use Travis anymore they’ve been shocking on price last time I compared even with a good historic customer special rates on stuff, not competitive even with Jewson let alone the leaner independents
Use them through my keyline account, but your right their prices are steep
Only for bulk, waste of time otherwise. I jewson are ok but way off on half the stuff they sell!
Jimoz
Both our local branches shut down at Xmas 3 or 4 years ago.
Yeh we had loads of smaller ones round here they all consolidated into a few biguns
And yet on the canal job the CRT had at least 300 bulk bags delivered off them...🤔
As @DaveDCB Says it think in bulk they are ok. I was getting aircrete blocks off them about 10 years ago dirt cheap till my mate went in there kicking off asking why he wasn't getting the same deal then the young lad who was sorting my prices got told to up them. Loose lips sink ships as they say.
So customer ordered 5 ton of bentonite on 20kg bags 😩. Doing 3 of the seasonal ponds I dug back in Nov to try and get the water to hold longer into the spring, they have been full all winter amazingly.
Did a pond by hand yesterday but 250 bags is a lot so using the thumb now- grab a bag from the edge give it a prod with the thumb to pierce it grab the opposite corner gives a lovely spread with the swing on the bag! Done a pond in 40 mins without getting out the cab Vs all afternoon back breaking work by hand!
