Interesting one today
Working with ecologist to prevent badgers undermining a listed wall where they’d built a set. So collapse set block passages and then mesh to stop them digging back down. Wall is listed for some reason, big lean on it abd been bodged back together a few times with cement
Ecologist client gap is 1060mm I’m like well my Kubota will go through 1m is it straight level and no sticky out bits? Yes no problem
Get there wall down so easy to get in, do one side wall think that was easy then he’s like we need to get other side! Step sticking out 100mm and outside tap not level etc tried for 20 mins took some paint off then was like this isn’t happening. If I do squeeze it in it might not get out!
So had to shoot off to only place with micro at 2pm hirecit for a week for 2 hours use.
What a horrible thing they are the jcb micros especially in 30 degree heat,
Worse DEWALT fan didbt turn up till lunch and mrs wouldn't bring it over to me lol
Bit like me today, Jcb and driver booked for 2 days and 10 loads, we did 6 yesterday, then done 7 today, followed by can you scrape abit more up, now there's another 7 on the deck. I'm not knocking having the work but never does the schedule any good, as well as other lads still on a job that should of been finished off but again the 'can you just' while your here.
L
Lynchy
Bit tight,trees same distance apart as track width,tree on right pita coming back cab side,have to track arm out under some,bit tip toe'y at 20+m out lol
Russell
What's that mesh for?
I bloody hate them jcb micros, point blank refuse to hire them!
Are the levers still opposite to the 3cx levers?
Yes hateful things
How to look like an amateur lol
Was 2 pm needed one to finish job ecologist had 3 hour drive back to Gloucester so had to be done rang rd a few and knew Alex aka @hiluxman didbt have any as we’d spoken early in week so Brandon hire had this 11.3 hours on it
Yes hateful things
How much did they clatter you the extra 20% you put on the hours?
Could have lent you my E10 for a couple of hours, probably wouldn’t be worth the time to collect mind.
hoping my dx10 arrives soon, they said august when I ordered it in march
but was literally need one asap, rang turners they had none in, rang bradon we were only in Fullwood so shot down, £1k deposit and 2 forms of id away we went
thing has never been greased but guess its go those silly Jcb wear shims, bin on bucket took some knocking out
