Toolsman
Hello Hive mind, I Have a Terex HD1000 here that has an intermittent starting/running problem in so far that sometimes you can start it, and she'll run then other times you turn it over, it starts but as soon as you release the key from the start/crank position it stops and will not keep running! I have changed the fuel rack solenoid, the starter ignition switch, its had starters and wiring connections checked but to no avail, its so intermittent that im getting nowhere very fast, any ideas or suggestions would be very welcome,
Best wishes
Toolsman
Best wishes
Toolsman
