Tb016 hydraulic oil filler nut cap
Could I suggest Antiseize or lots or teflon tape when it goes back together?
Just a plug with an o ring for a seal which gets plenty oil on it when it goes back in I don't think there's anything else you can do. They don't seize in they just end up v tight which i assume is just from heating and cooling and pressure in tank going up and down through use. I only ever give the plug a v light nip when it goes back in but it makes no odds when you need it back out after months.
