benshudson
Hi guys
I have a little Takeuchi digger TB016. I think it’s a 2000 model.
The blade recently lost power, albeit still can lift itself and lower itself, just can’t do much more than that.
I pulled the cylinder and had a cylinder guy open it up and look at it. He said it’s fine and has no leaks visible from the outside while in operation.
I’m thinking it’s the block control valve? The lever cable for the blade doesn’t seem to be blocked or broken.
I’ve linked some pics and a video of me operating it below (google pics link - actually I had to remove the link. Will try to add some other way).
You’ll notice when I have the blade on the ground and try to lift the machine weight on it, the engine bogs down as if it’s working hard, but the cylinder doesn’t further actuate.
Any help?
Any help?
