Takeuchi TB210r seat Replacement
G
greeen210r
Does any one know or is there anyone with a 25/26 yr Taekuchi Tb210r that could tell me what make/model seat is fitted?
My machine is a 2016 and had the KAB P4 seat fitted. KAB have stopped making this seat and so Takeuchi obviously have a replacement. I'm trying to find out what make and model the newer version seat is.
The KAB p4 is 450mm wide. The alternatives I've come across are 470/480 wide.
Max room between control arms is 480 so I'm a bit reluctant to order and try. Aswell as the width, the alternatives seem to be deeper aswell so not sure if that would work either.
Ideally I'd like to put the exact newer replacement seat on to avoide any potential fitting issues. Takeuchi direct supply though is rather steep 😬.
Any help would much appreciated.
Thanks.
Well I’ve been on a breakdown on one today, there are no markings or makers plate on it, and the machine was a 2022. There are others in the yard I will look tomorrow for you👍🏻
G
greeen210r
Thanks for looking Mick..appreciated. Attcahed 2 pictures. 1 of the old style P4 and other is the new 1. Not sure if the 22yr had the new style tbf. The old style P4 had it printed behind the folder pocket on the back of the seat. Obviously new 1 I dont know, but sure I read somewhere it 'may' be on the under side...if so, hopefully visible with seat slid forwards 🤔.
