diggerjones
Anyone ever used snow chains. I've got a Nissan cabstar and if it goes anywhere near grass or off the hard it gets stuck. Was wondering if they would work in this manner
What he said. Right faff if you need to do it semi regularly, you're better off getting knobbly tires or a 4x4.\They aren’t much fun to fit, and I’d imagine less so when you’re stuck (plus taking them back off covered in mud would be pretty miserable too)... We run 4x4 tyres on the back of our cabstars which helps a lot, and always have a tow rope with us!
Single. Twins aren't as bad,less pressure and more footprintIs it single or twin rear wheels?
I've done a bit of muck shifting in me youth, worst thing was a foden hook lift with a automatic gear box, useless on tip. Late 80s truckBit of sand under wheels works when or 18ton gross lorrys do that
That sounds good. See if you can root it outIf you put knobbly tyres on, just check that they are the correct ply rating for the truck.
We used to have, still have somewhere, a four legged mechanical claw type thing that you clamped round the tyre, worked quite well in mud on our old Cabstar’s. No idea if you can still get them?
Are you sure it’s just not a wheel clampIf you put knobbly tyres on, just check that they are the correct ply rating for the truck.
Ha. Or what's left of itAre you sure it’s just not a wheel clamp![]()
The (knipetak) (directly translated = pinch grab) as we call them is nice to get you loose or through the snow or mud
quick to put on and take off,
but nothing to drive by the road With, too much bouncing
View attachment 1140View attachment 1141
