Where was that? Looks expensive. Doesn’t look to be high tip, just swivel- surely a proper tracked dumper would be a better way of going about it?Saw this today, quite interesting
That the reversible Wacker?I figured out how to pick up my Wacker with my tcp dumper and load it in the dumper without the digger yesterday.
Well chuffed because it's a heavy lump to move about
Yeah I was curious for the Avant 17kAren’t those track kits like £5k a corner? Only £32k for new yanmar 3 ton swivel tracked dumper
Ahh but a "converted" wheeled dumper can have a Idiot with a standard ticket destroy the very expensive tracks rather than giving a Expensive Idiot a tracked Dumper.Aren’t those track kits like £5k a corner? Only £32k for new yanmar 3 ton swivel tracked dumper
Sadly this is the truthAhh but a "converted" wheeled dumper can have a Idiot with a standard ticket destroy the very expensive tracks rather than giving a Expensive Idiot a tracked Dumper.
Yeah the skip goes nearly 180degrees so more or less upsidedown. I sacrificed a road pin and welded four hoops to the top of the skip. They work a treat for filling bulk bags too.That the reversible Wacker?
TCP tips 90 degree and close to ground? Strap or chain to top of skip?
Pictures or it is not true!!!Yeah the skip goes nearly 180degrees so more or less upsidedown. I sacrificed a road pin and welded four hoops to the top of the skip. They work a treat for filling bulk bags too.
Thats going to go viralNot particularly smooth yet but should improve with time
That works really well, if you leaned the Wacker right back and chained onto the plate at the front, would it be able to pull it on without needing to man handle it?Not particularly smooth yet but should improve with time
I need to get a smaller chain and have a go. Like I said it flips over 180 but when I tried today it twisted the Wacker sideways.That works really well, if you leaned the Wacker right back and chained onto the plate at the front, would it be able to pull it on without needing to man handle it?
Maybe a bit of pipe welded on the front top of the Wacker then stick a stout pin through the hoops on the skip might make it safer and easier to lift .
