Bob
The older the plant less electronic most older plant nearly any good fitter would find away round a problem like rad leaks,put in egg whites, burst hose good tape wrapped around etc
635H Swing Boom Skidder
The 635H swing boom skidder performs in very demanding and restrictive terrain conditions. Soft ground or steep slopes.www.tigercat.com
And only your imagination limits what the grapple could be used for...![]()
That will feel like 50Top speed 15kmh ?
Now we're talking....if the op thinks this is going to ever get a sensible conclusion....find a barracks
Now we're talking....if the op thinks this is going to ever get a sensible conclusion....![]()
And get the other person in the story to follow with the fuel tanker who inadvertently leaves the valve open leading to a big explosion whilst they raid a supermarket for foodWell if raiding a barracks is happening have a look for the fv180 combat tractors replacement .... the Terrier with its 700hp Cat diesel![]()
Don't be so silly you conspiracy theorists you'll be telling me next Mark Dickford is a ****If you look on X twitter the start of the film is all ready written ( known as Conspiracy Theorist ) Switch on 5G and everyone who have had the jabba jabba will feel ill and slowly die off . Anyone who refused the jabba will be hunted down be the army which have been trained in Turkey and Ukraine and came over in dingy and housed in top hotels and just waiting for the orders and your heroes have got to escape![]()
And get the other person in the story to follow with the fuel tanker who inadvertently leaves the valve open leading to a big explosion whilst they raid a supermarket for food![]()
why not .... sounds like there'll be no one alive to stop you .... and they have some gloriously 'proper' toys to choose fromWell if raiding a barracks is happening have a look for the fv180 combat tractors replacement .... the Terrier with its 700hp Cat diesel![]()
Agreed, slowly losing coolant or hydraulic oil, small leak of coolant would eventually cause a heat seizure, but it would be a dramatic scene when one or more characters make a dash to an old combine out in a field to collect coolant or hydraulic oil!I'd say the way your characters will be driving it, a holed radiator or a torn coolant or hydraulic pipe is the most likely breakdown!
Try and find one that has anti puncture liquid in the tyres, or drive it under a fly over while changing a wheel! If you pull into Watford Gap services on the way down south, they’ll have all 6 off in 20 minutes![]()
Not sure how an ecu would cope with a bullet hole in it!The older the plant less electronic most older plant nearly any good fitter would find away round a problem like rad leaks,put in egg whites, burst hose good tape wrapped around etc
Good man Bob, thank youThe older the plant less electronic most older plant nearly any good fitter would find away round a problem like rad leaks,put in egg whites, burst hose good tape wrapped around etc
