Justme
Got a few issues I am trying to sort.
1999 HR16 3500kg
1, Loosing hydraulic oil. It is dropping out of the main body via the drain holes.
If you tip the body you can get it to come out either side & also forwards under the flaps.
Mostly battery side but some on the other side too.
There are pipes running both sides engine to under floor area. None are damp at either end.
Tried pressuring each service one at a time to see if it ups the leak but cant see any change.
Some days no leak others more. Could be temp related but pipes to cooler are dry.
Is there any where basically under the seat area (or any where else) that the oil could be coming from?
2, The quick hitch keeps dropping the bucket quite often & the grab less so.
I have seen that some gas axe the pins out & replace with long pin. Is that the only fix?
Any ideas on a clip to stop the activation pin rotating?
3, Just about to order some new pins & bushes.
Any tips of fitting bushes, Not just the fitting but in handling the dipper whilst doing so.
From the two main pivots to the bucket end.
I have a bearing screw thread tool.
Will that be enough to get old one out & new ones in?
Cheers & thanks for having me, this is my first post here.
1999 HR16 3500kg
