Jimoz
Imagine buying a machine like that used you'd be chuffed it's a minter
Within about a week or so I'll be over there again to collect my reconditioned pecker - nice old Arrowhead S20Well i would say he needs to look more into what hes buying as that model is not a 1994. Thats a CX210B
Tidy work. Do you think the clay will let the water soak away eventually???About a week or so ago a neighbour told me about the new facias and soffit fitted to his bungalow. Of course they sold him some of that nice black powder coated steel gutters and downpipes
Then they explained that he really did need an extra downpipe on the North East Corner. This meant that the rainwater now spewed out onto his nice block paving
"Can you just........put a new soak away in for this please"? said Terry
So I explained the current regs and 5m away and plastic crates etc. He though that a little hole filled with rubble would do it
So here's a few snaps showing the fun that I had digging into hard formation layer clay.....
New black pipe on NE Corner and pipes laid out ready for marking
Pipes laid and marked up to 6m away. Noet the block paving
Had to break out a corner of the foundation to get the pipe in. Note my trusty Titan breaker
Digging out the hole for the crates. Terry owns the 'field' next to his place, so 'muck away' to my place nearly opposite was easy
Hard formation clay so had to get down and dirty for the corners
The 'new' lifting eye and big hook' come in so useful with working solo
Soon have this job 'wrapped up'
Then I got stoned and it went downhill from there
Site inspection from 'Clerk of the Works', Terry. Usually see him most days. His wife is in a care home, he has had a new hip recently. Then a few weeks ago in hospital after a fall. Stubborn old bugger is fiercely independent and still drive his nearly new Lexus LS450h most days. We are a hamlet of only 22 houses and all look out for each other. Terry is like a second dad to me
Before you all ask, the backfill went OK with much of the clay sticking to my tracks! Back in a few weeks to sort out the lawn with top soil. The down pipe has now been extended direct into the 110. Jobs a good 'un
That's it for now from a wet and windy Sunday morning in North East Essex![]()
Yes, I certainly hope so Shaun! Great questionTidy work. Do you think the clay will let the water soak away eventually???
Yep, have worked with ground workers and builders that second guess it and do it the hard way.Lay pipes then mark trench why haven't i thought of that before. Saves any messing with adjustable bends because the trench direction isn't quite right!
Wonder if the plants in that planter do any better this year.
Layers of old gravel is what I have been missing on our swamp plot!!Yes, I certainly hope so Shaun! Great question
There are 2 other soakaways at this bungalow, done about 25 years ago with rubble and still seem to be working OK. I think that have about 1m3 in the ground (0.8m3 crates) should do the trick - hydrostatic pressure should do it. Hole was open 2 days and had rain overnight. Water in the bottom did seem to be getting away. When digging the hole, I did hit layers of old river gravels which should help. I know you have been working with clay recently, so are there other solutions available![]()
That’s a good idea with wooden formers for big jobsDittowe always lay bends and pipework out first so we get the angles right - then speedline it up..... have always been going to knock up some sort of 45°,30° and 22° angles out of wood to save putting the pipe and fittings out but havent got round to it as yet.
Yep sometimes use the spray stuff, but the lube has other uses and is cheap as chipsget the cans of spray silicone. better than the lube and less messy
They are what I call 'come in handies' - got a yard full of the stuffI got a job lot off a big site years ago. Had bloody loads of the stuff. Think I've still got about 30 long radius 90s in osma. I use then everywhere I can. Have used them horizontally cut open with benching and risersView attachment 12257View attachment 12258
That's all well and good if you know what's underground.Dittowe always lay bends and pipework out first so we get the angles right - then speedline it up..... have always been going to knock up some sort of 45°,30° and 22° angles out of wood to save putting the pipe and fittings out but havent got round to it as yet.
cuminfas, hereThey are what I call 'come in handies' - got a yard full of the stuff![]()
Yep, the hours are genuine now 34.7.Within about a week or so I'll be over there again to collect my reconditioned pecker - nice old Arrowhead S20
Didn't realise that the photo of the Case would generate so much interest. Thought it would be about the old tractors
Meanwhile here is another snap that I took last week of the Case. This might give you a few more cluesView attachment 12243
Th more observant will notice that the tracks are 'like new' and not all beat up![]()
