Routy56 - can you just....
Routy56
Routy56
So now I am 'semi-retired' catching up with all those jobs at home ;)
We closed down our swimming pool after last summer and I'm gradually 'decommissioning' it.
We've had this pool for about 30 years and has served us well.
Simple Clarke UG pool 27'x15'x4' half sunk in the ground.
Cheap agricultural polytunnel over gives free heat with the water getting up to about 33c in the summer :cool:
The liners get brittle and leak. We have had 2 replacements.
As well as two replacement covers on the poly tunnel and now all the steel work is rusting away :rolleyes:
Today's work:
There's a 5T of soft sand there which I'm gonna recycle into 1T baggies
The steel sides are a galvanised corrugated material, and is now well and truly past it.
Note the tree roots are shooting again. I sprayed off the brown ones with Roundup.
The whole bottom surface of the pool had been comprised with roots from the neighbours poorly maintained big fcuking Poplar trees :mad:
This is as far as I got today - well cleared what you see here to the end.
All 'handballed' over hand tools and wheelbarrow etc.
But the big bonus was that was that I was working in the dry of the poly tunnel :cool:
Today's work:
My life would be over if the pool is not replaced when it comes to the end of its life span. I did put a concrete base down for it with block walls on their sides. My bad luck will be that she will want a bigger one that doesn’t fit!!
Routy56
Routy56
Yes me too :ROFLMAO:
BUT with our pool, our children had grown up with this pool with our neighbours kids.
Our daughters are now 44 and 42 and were still using it with our grandchildren.
So, our 6 grandchildren have literally grown up with the pool and their friends.
The above photo shows Ryan with his two mates, and 3 grandchildren last September.
At that point I’d kept it going with leaks for 2 years. The water bill was halved when I stopped.
The best thing was water quality. I used a large heavy sand filer for years which polished the water lovely :cool:
Like your concrete base and block wall (similar to my retro set up) but it can be restrictive.
In our case, it was a simple last minute hole in the ground. Metal work bedded in.
Then levelled the bottom with 5T of soft sand with coves around the edges.
I have always said that I was going to put in a ‘proper‘ in ground pool.
But SWMBO obeyed said that we have better then it’s to spend our money on :ROFLMAO:
Routy56
Routy56
Last weekend was car fix day at my workshop for both my son in laws. Well I have got a nice warm barn heated with a log burner. And it has an inspection pit 😝
Rods ‘new’ car is a very nice 2014 Range Rover Evoke. It’s got the 2.2 diesel engine and a 9 speed auto box.
When accelerating at 45-60 there’s a vibration like a wheel out of balance. He had them checked and done. Had an independent specialist check it over and gearbox was fine but. He said that an oil change may cure it 🤨
So we did an oil change over my pit as per the evoke owners club guide etc
And guess what no difference ☹️
So any of you guys have similar experiences with one of these?
My best guess is a drive shaft starting to wear out 🤓
......When accelerating at 45-60 there’s a vibration like a wheel out of balance. He had them checked and done. Had an independent specialist check it over and gearbox was fine but. He said that an oil change may cure it 🤨
I'd concur with that IMHDO .... is it 2 or 4WD?
can't see how an oil change'd make the slightest of difference :unsure::oops:
Routy56
Routy56
It's a 4WD with some sort of Haldex system.
When I had a succession of Disco 3s it was reported many times about the washboard effect.
This tends to give the torque converter hell ;)
One cured a a power flush of the auto box.
With my Disco 3 I was ahead of the game and believe that prevention is better than cure.
So I upgraded the auto box filter, which was a standard ZF box upgrade. Then I did my own power flush.
Basically you pull the hoses of the ATF oil cooler and feed in new fluid and collect the old black stuff.
Stop when it comes clear - gets all the tish out of the torque converter :geek:
So with Rod and Nicola's Evoke gonna get it back over my pit and give the drive shafts and good old shake.
Failing that it goes to the main stealers soon for a LR recall job.
They should identify it - they are the experts 🤪
Yep that what they did with my nearly new Disco 3 HSE whilst under warranty :rolleyes:
dealer 'mechanics' these days are are just box fitters .. take it out the box and fit it .. diagnostic skills're few and far between, unless you're lucky enough to get a 60 yr old, old skool fitter on the job.
Routy56
Routy56
Yep - that's why I don't trust 'main stealers'. Last year the Nissan dealer tried to stripe me up with over £700 work of work advised during the 50 point safety check. This included worn out brake pads and discs on a Navara with only 20k on the clock :mad:
When they emailed me for feedback I really let them have it with photos.
Got a grovelling apology from the Service Manager who I told, "You are obviously setting targets for your technicians to bring in more work. Well it won't with with me as a business user with a nice plant workshop" :ROFLMAO:
Mind you to be fair following that they assigned a nice technician called Ruth, in her early 20s, to deal with 2 warranty claim jobs.
She successfully, diagnosed:
1. a failed battery - Nissan/Renault had a bad batch
2. a failed NOX sensor
Both replaced under warranty with a nice video from them.
And I actually got to chat with Ruth when she bought the car round from the workshop :)
Ruth had obviously been 'skooled' by someone with a bit of nouse then :giggle::cool:
just about all dealers are 'looking' for work when they get yer chariot in their mitts ... someone has to maintain the climate controlled workshops for them :mad:
I think thats all you can do on some 9f these modern cars, there is no rhyme or reason to some of the problems.
Heard the other day that PSA vehicles with starting problems is often solved by changing the wing mirror
Property Services Agency ????????
Canal Navvy
Canal Navvy
Suspect PSA refers to the French/Italian partnership (range rover v8 diesel, Corsa diesel etc)
Know of a a mighty Mercedes Unimog that failed to make progress due to a failed sidelight bulb that was ignored too many times on start up 😁
Diggerdavey
Probably where the exterior temperature sensor is located.
