Recommendations for a good digger bush/pin supplier?
As above. New Holland are a nightmare/very expensive to get parts from, however they do give full dimensions of bushes and pins required in their parts list which is helpful.
So reasonably priced supplier recommendations please.
Engineering firm probably cheaper for you, or one man and his lathe in a garden shed!
It's going to need a CNC lathe to put the grease ways in, plus the bush will need hardening?
I've got a lathe and a shed, but there must be a firm who specialise in this|?
Could put the grease ways in with a mill and dividing head. Or with the screw turning setting on a lathe if you have a course enough gearset
why? long series drill
Digbits haven’t been too bad.
Bob
Bob
When I wanted some new pins for a D4 I went to a local engineering firm who made them for me with grease ways and threaded for nipple
Send me your bush sizes I may well have them on the shelf
Swing cylinder kingpost bushes- 45.12mm ID x 57.96mm OD x 44.5mm L. 4no
Main boom pin bushes- 55.18mm ID x 71.01mm OD x 50.5mm L 2no
Bucket pins - 45.18mm ID x 61.01mm OD x 50.5mm L 4no
Odd balls if ever I seen some😆
Il check the shelf tomorrow as some of the older hitachis had some odd ball sizes
Out of interest how much are NH quoting?
I don't know yet because the parts guy at MJN tractors is having a nightmare getting any info from them. But figures of £300 for a bush were mentioned. Too much.
I first tried Does, at first parts guy was helpful, but then wouldn't return my calls and just sent an abrupt email saying I should use a different branch which were nearer! It doesn't matter a shits worth of arsehole which branch you use if it's mail order, and if one branch is backhoe specialist (which i highly doubt) then why not tell me to begin with??? Not impressed. I get the feeling CNH construction just don't care.
What grade of ground steel should I use for the pins?
My local Ernest Does is the main HQ, if it’s a last resort then if you give me the part numbers I can drop in and price it all up when I'm next passing. Im not saying it’s the best option, but if it’s a last resort or you just want to compare prices then I don’t mind going in, I go past it regularly.
