diggerjones
My brother has got a log splitter with a ram thats leaking. He can't see how to split the ram. There's just a threaded hole.
does look that way AidenThe gland may push back and a metal ring come out to let it out?
Looks like that to me too knock back the gland block 1/4” the you should see a metal ring inside the tube flick it out and bobs your uncleThe gland may push back and a metal ring come out to let it out?
looking at that pic again Dylan, I'd say that the threaded hole should have a short M6(?) in it with a large mud wing type washer to prevent the end cap going back on its own accidentally .... can see the witness mark where the washer wasand where it overlapped the edge of the cylinder wall
Yea like druid says the washer likely stopped it from going back to far when working. Have done a few like that, mostly smaller onesLooks like that to me too knock back the gland block 1/4” the you should see a metal ring inside the tube flick it out and bobs your uncle
has he relieved any pressure in the cylinder's return side DylanWell hes actually started on it and you all were right but he still can't get the ring out. I will see if i can copy and paste our conversation
Cheers Dylan
There’s no cutaway for a screw driver, the cap isn’t threaded. I’ve used the sticking out bolt to turn the plate, it does go in or out when turned. I’ve smacked the hell out of it. The end plate is about an inch thick! It’s as if there’s something stopping it going in. The shaft turns, the base plate turns and the circlip can be move. It’s the pushing it into the cylinder that’s impossible. I thought of using the machine to pull it in but the pressure would push out not draw in. My neighbour who does cars up, can’t think of anything. I’m going to put some oil seal leak stopper in the hydraulic fluid to see if the stops the leak, but at 30ton pressure I’m not that hopeful.
prevent accidental withdrawal of the end cap by getting summat stuck between the rod end and the cap ??Good thought Graham. Would there be any reason for that. Will let him know
only other thought is a detent pin that'd have to be aligned with a small slot in the end plateI drained the ram, so no return pressure. The plate moves relatively easily (a hammer using a drift on the M6 bolt I put in the threaded hole. I can see the back of the plate through the inlet port, I’ve tapped the plate round 360degrees, no castlletations/marks/grooves/slots. I can’t get the clearance to get the circlip out. I’ve tried to force feeler gauges between the plate and circlip, there’s no where near enough space to manipulate the circlip out. I wondered whether muck had been force between the plate and cylinder, it’s clean. I’m going to borrow an endoscope to see if that sheds any light.
can't imagine the adapter is into the cylinder MogHave you taken the fitting out completely just in case it is stopping the gland from dropping back into the cylinder?
