Can someone come up with a quick connect that has a tang at 90 degrees to grab hold of to make it 100000% easier to engage/disengage the little sods.
Abysmal design.
Abysmal design.
My Unimog has got cast alloy QR`s on the front with a little handle/tang cast into the other collar.Can someone come up with a quick connect that has a tang at 90 degrees to grab hold of to make it 100000% easier to engage/disengage the little sods.
Abysmal design.
Manitou`s have that as well.The switches on the new jcb loadalls to depressurize the aux circuits are brilliant
can well believe it if used dailyThe amount of hassle they save, Worth every penny!
I put something up on the old forum years ago about these, pretty sure the name and number was there as well.have you got another link to these? it doesn’t seem to work
hmm ... that link is three years oldhave you got another link to these? it doesn’t seem to work
thanks very much!! il definitely be ordering some of those
nifty idea that OllieMy first tilty started to be a bit hit and miss sometimes, so just put a “T” piece in, would just crack it if needed, and it did the trick, 20 seconds tops, and it was sortedView attachment 12536View attachment 12537
Originally was going to stick a little tap there, but when it was on it just looked to bulky, so just put that it, just have a bit of rag handy to wipe up any excess oil.nifty idea that Olliemight just 'nick' that idea
yeh ... tap'd be a bit of a liability and'd make a hell of a mess if it got caught inadvertently .... or worse ... knocked offOriginally was going to stick a little tap there, but when it was on it just looked to bulky, so just put that it, just have a bit of rag handy to wipe up any excess oil.
