P
Pretend Farmer
Hi , just purchased a Hanix H24A and a thwaites 3t dumper . I've a problem with the H24A and someone recommended this forum. Is there a specific way or place to post technical help? Cheers
welcomeHi , just purchased a Hanix H24A and a thwaites 3t dumper . I've a problem with the H24A and someone recommended this forum. Is there a specific way or place to post technical help? Cheers
Cheers , will do , no problem with banter , I'm on a Land rover forum so sarcasm comes before any real help, but the help is also there, all part of the fun.welcome.... start your own thread, probably best in construction equipment, stating the problems, pix are always helpful and some one'll be along to chime in with some help .... be prepared for witty banter also
Hi MickMorning what issues do you have?
Are we talking fuel hose, if you can find the tank and where the hose is attached, put it off the tank get a roll of new fuel hose, find a bolt that fits into the hose tightly, put it half into each hose put them together, see if you can pull them through to the engine bay.Hi Mick
Diesel return pipe on the Hanix has perished and collapsed internally. It disappears under the cab and can't seem to see where it goes. I'm assuming back to the fuel tank but again seems impossible to even see how to get to it. Also its a three cylinder and it runs like a bag of Sh** it may well be how they are but the vibration makes it seem like its a 4 cylinder running on 3![]()
Yes correct on the Engine 3cyl. Like that idea trouble is in ant even see bottom of tank or even how to get to it, looks like a cab off job, nightmare. CheersAre we talking fuel hose, if you can find the tank and where the hose is attached, put it off the tank get a roll of new fuel hose, find a bolt that fits into the hose tightly, put it half into each hose put them together, see if you can pull them through to the engine bay.
Guessing it’s a mitsi 3B engine?
The bleed off usually goes to the top of the tank or the top of a fuel filterYes correct on the Engine 3cyl. Like that idea trouble is in ant even see bottom of tank or even how to get to it, looks like a cab off job, nightmare. Cheers
I thought he said where the hose goes back to tank! But i think he meant the supply from the tank!The bleed off usually goes to the top of the tank or the top of a fuel filter
Sorry can you clarify weather it’s supply fuel hose or return? Running issues on those old mitsi’s sometimes down to valve clearances.Hi Mick
I'd be inclined to put some Oetiker clips on the joint ... pull too hard and you'd be in a world of tish if they separatedAre we talking fuel hose, if you can find the tank and where the hose is attached, put it off the tank get a roll of new fuel hose, find a bolt that fits into the hose tightly, put it half into each hose put them together, see if you can pull them through to the engine bay.
