Piling
diggerjones
diggerjones
Not sure how it works, but. Machine pushers pipe into ground 7 metres. Loading shovel fills pipe up with big gravel. Can anyone give move information.
They fill the bottom of the Cason drop piles with stone/mot when using drop hammer so it’s not metal on metal.
As Conor says, be vibro piles. Intention is to improve the bearing capacity of the site by compacting columns of a "Graded" material with known properties. Very effective and cost efficient in the right applications.
diggerjones
diggerjones
This job is for 2 houses being built on part of a field we rent new to our house.
Your both correct, but i can't understand how they get the stone in the hole they've created. There not drilling
presumably the spike pipe cap stays at the bottom of the hole and gets buried????
new spike cap for each hole ?
diggerjones
diggerjones
Never thought of that. Makes sense. But, 140 piles for 2 houses i don't think that would be feasible
Got to be cheaper than concrete piles and I'd bet they would want the same amount. So much for going green. Structural engineers seem to find it a a competition as to how much material we can force into the ground
Dug afew footings through them before, you know they are there alright!! And much easier to dig than with concrete/metal piles everywhere!
Done loads of industrial units where they used the stone piles. Firstly you get some additional load bearing on the actual stone columns and secondly it can improve the load bearing o Bt he existing ground as when you force and vibrate the columns it compacts the surrounding ground. Only works in certain ground conditions but a cheaper option when it is suitable.
Cementation used to do similar work. They had a dumper with a chute on the front, withdrew the poker and tipped the stone in, then dropped the poker in to compact. Rinse and repeat until the hole was full. It was remarkable how little soil needed clearing up afterwards.
