pc138-11 2 speed tracking
mart1602
evening lads,would anyone be able to point me in the right direction to find the solenoid for fast track as i have what i think is a bad connection.many thanks
If you know the dimensions and spec @V8Druid had a link for a seller who specialised in solenoids
On my pc45 it’s under floor in the cab I took the side plate off just under the door and there’s two together one does the two speed travel the other the dead man’s handle
mart1602
well the problem has now escalated ,slew brake wont come off now tested coils and earths which are well within spec have even swopped wires over on coils but still brings up same fault and fault code looking for any ideas before having to get dealers out .thanks
I had a pc138 give me problems with the slew brake lately.... it was the switch at fault
mart1602
code says faulty solenoid but it tests fine with a meter ,in theory by swaping wires over should produce different code but it doesnt mbk is nearly 100 miles away will be close to a grand for them to come look at it
mart1602
would have been nice but unfortunatly not the problem:(
can you trace back via the hydraulic line to the brake? May be as simple as bad connection/broken wire.
I had the same issue with the 'Drema some time ago and although the coil tested fine, swapping a coil over from elsewhere cured it, so new coil bought and has been fine since
mart1602
Been a while since I was on here no bloody Internet for nearly 2 months have posted another thread which I hope has the solution to this problem
But the Gov are 'sposed to have rolled out access for all across Wales Martyn :rolleyes::mad:..... give your MP some serious sh1t ...... 2 months is appalling and beyond any excuses ..... you have my sympathies .. ours usually goes west on a Friday, so's a minimum of 5 days 'fore it gets looked at and that seems like weeks :mad: :mad:
bobthebuilder
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
joker are we
mart1602
I signed up for fibre with a new provider said it's at the end of my lane and would be in by the end of the next week, they came as promised can't install cos pole by house is elec and phone shared so need special permission to use pole .
Still no connection but have now given us a Vodafone hotspot thing with a sim card till it's done
