I’ve got some of the meter long ones, use them for pulling joists together when fitting noggins.
Picked up a pair of those for a tenner at an auto jumble last year, good wire brushing and a bit of oil and they were good to goI’ve got some of the meter long ones, use them for pulling joists together when fitting noggins.
Higher flow rating, a 1/2 set of these would be comparable to a set of 3/4 flat face. less pressure drop and much better qualitylook for all the world like A,s .....
what's the difference??
TBH I like ISO A,s ... much easier to use -- down side is the spillage, coupling/disconnecting ......... and they do not like dirt / crud / tish / etc. ...... presumably these have the same issues as conventional A,s??Higher flow rating, a 1/2 set of these would be comparable to a set of 3/4 flat face. less pressure drop and much better quality
