Mini Digger won't track straight
HeliPilot
HeliPilot
Hi All
My JCB 8026 has stopped tracking in a straight line, one track is running much slower than it should.
Any suggestions where I should start first?
The machine has only covered 500hrs of relatively light work.
Has it started doing it since your Tiltrotator has been fitted? Is it a case the that the hammer line is getting flow? Causing one track to go slower?
Does the auto idle work?
HeliPilot
HeliPilot
I'll try it with the tiltrotator disconnected. But I think this problem started befor it was fitted..!
This machine doesnt have auto idle.
Many Thanks
HeliPilot
HeliPilot
I've disconnected the tiltrotator but its made no difference
rotary coupling seals bypassing -- I know it's only done 500 hrs but could be a Friday (or mon., tues., weds., thurs.) machine ???:oops::cry::cry:
HeliPilot
HeliPilot
Rotary coupling seals? I've never tackled anything like that, are they accessible from underneath?🤔
not an easy job ... try swapping lines to drives left to right and see if the problem moves
You beat me to it, I would go for the service change side to side, or if at 500 hours have the final drives been checked?
HeliPilot
HeliPilot
Is there a fitter in Surrey area that would take a look at it?
HeliPilot
HeliPilot
Hi Mick
I had a burst quick hitch hose which I replaced, and when I got it all back working the tracking seems to have sorted its self out.
Oddly the tiltrotator (tilt) has been very fierce since it was fitted and that now is also very smooth.
Thanks very much for offering to help, but for the moment finger crossed its all ok…!
Regards
Les
