Micro machine post holer setup
Looking at getting a little micro to do mainly fencing and the odd bit of landscaping. Are they man-enough to handle an auger to make 600mm holes with a 9/12" flight ?
Depends alot on the ground. A 12" hole round round here you'd need an 8 ton machine. Withe a micro you could almost dig out with small bucket
Get a larger auger motor. I run the pdx2 (30-55lpm) on the micro (20lpm flow). It’s a bit slow but can drill through mudstone with rock teeth on the auger.
A ‘micro’ auger would turn faster but stall easier.
Micro should manage it fine, I had a 300mm one on my old tb108 at 1.2m deep
Yes that'll be fine at 250 you could nearly drill it with a handheld but I wouldn't want to😮. A machine mounted auger is definitely the way to go
Steve
I would say you will definitely come across ground that you can’t bore with a300 mm auger on a micro. Also check your micro will lift high enough to clear the ground ie total length of auger +motor & swivel bracket.
You will bore a surprising amount with the right torque and teeth. If you spec the right motor to start with then speed and downforce are your limitations.
I think we are missing something here with new machines, Kubota say they can’t deliver new until January 2022, but you have to pay for them now! If you were able to buy one now and in January 2022 sell it back to them unused it would be second hand!!
Russell
Bit of a tangent here but I read the other day bobcat e17z and e20z are going to be made in china. The article didn't mention the E10.
Looks like it's the models on the zero tail chassis. Ostebsibly to respond better to Chinese demand. I assumed the Chinese used home built kit- it turns out that Carter are so bad even the Chinks themselves won't touch them! :ROFLMAO:
