Micro Digger Comparisons
Is there a specific brand of bin bag you'd reccomended??
Don’t do what my old man did and put flash band on it, seals it but in summer you end up sticking to it and it all over your car seats.
That thick heat shrink pallet wrap is good, just use heat gun not roofing blow torch
Maxus
I appreciate the advice, but I can confirm that a bin bag isn't a good solution. However 20221105_132543.jpgit did make the seat feel more ergonomic
Think it’s a bit wider than that, Brendan.
Just seen 700mm doesn't look like tracks expand but comes with weird land rake, thumb, thumb with shovels and a weird set of forks that attach to the blade
You’ve been trawling as well. I think Jansen market them as their own machine. Jansen sell two other machines which definitely haven’t been designed by the same people. Shame it isn’t a bit narrower as there’s no advantage over my Kubota for access. A 600mm width on expanders would be a smart move, the amount of times you need a machine that small you don’t need to be paying Yanmar or Kobelco prices, even if you can find one in the UK.
