Feral as Fk
It's not too hard to do, Often did it with my mini's.Fair play getting it in the skip in the first place![]()
Not on my low loader as couldn’t get it in to longbut this is the gap I had to reverse into 10’ wide at the pinch point
so had to use my 7 meter one just a bit of over hang
I’m a bit disappointed that you used a trailer and haven’t ‘trained’ your crane to let you use it FOW.....Not on my low loader as couldn’t get it in to longbut this is the gap I had to reverse into 10’ wide at the pinch point
surprised he didn't stick his turntable bed on and park one end on that, then take the far end on the hook and back it in ..... with a couple of skates under his rear legs to keep the front axle on the floorI’m a bit disappointed that you used a trailer and haven’t ‘trained’ your crane to let you use it FOW.....
f**kLorries are over rated![]()
Johnny FlipFlop's Almighty Truck-up's : Lorries are overrated nowadays
Lorries are overrated nowadayswww.facebook.com
Seen that here locally, but it was only an 8 tonnerLorries are over rated![]()
you're kidding James .... that machine has to be well over 20tNot necessarily illegal though, without knowing all the facts
Looks like a 13 tonner to meyou're kidding James .... that machine has to be well over 20t.... it was pushing 10ft wide
the track frame is wider than the trailer bedLooks like a 13 tonner to me
Still a 13t machine but looks like a zts, get your eyesight checked old fart.the track frame is wider than the trailer bed
ok .... but weighing closer to 17+t on that track frameStill a 13t machine but looks like a zts, get your eyesight checked old fart.
Won’t be many, if any 13t class machines that won’t overhang a little. He also might not have it loaded dead central. A 20 tonner would have the center of the tracks sitting almost on the side rave of the trailer.the track frame is wider than the trailer bed
W
