loadall 532 gear issues
markyf92
Hi
I have a Loadall 532-120, 1st and 2nd gear work fine, when you shift into 3rd it goes back into 1st gear, and when you shift to 4th it goes into 2nd gear ?
I've swapped the some of the solenoids round but no difference there..
hope that all makes sense and any ideas ?
Is there a kickdown button that's been switched
On the agri versions there are multiple gearbox modes that all make the gearselector do different things
Yip sounds like it's been jigged to not go fast, is it always done it or just recently started doing it? Could be a bad coil or fuse 🤔
If you've swapped solenoids to no avail i reckon you should be checking to see if there is power going to them all. As above sounds electrical but if you check at gearbox end first to rule it out.
