Mason
Hello all,
I am new to this forum and in need of some help. I have a Aveling Barford 140 with a Leyland 680 engine.
It is blowing into the water jacket. I bought it in October with a stuck engine, when I got it freed off and running
it was a bit heady so I pulled the heads off and got the valves and seats re-cut and put in new valve guides.
I also had them crack tested, all was good. I also replaced a liner with a crack in it with a new piston and liner.
When I got it back in one piece I put it to work on the mole plough but it started blowing into the water as soon as it got up to working temperature.
It was nothing horrendous, I could work it for half an hour or so be for I needed to top up with water. So I persevered to get the field done and then I parked it up. Before Christmas I stripped it again, this time I pulled out all the liners and checked for cracks and had the heads crack tested again (pressure tested).
Again all good and I checked the block with a strait edge. All looks good so now I have it back together again and it is just the same blowing into the water.
I am scratching my head, I can not think of any thing that I have missed. Do any of you have any ideas?
