Laser level
Laser Levels Online
Laser Levels Online
Another good option is the Laser Levels Online | Outlet located here:
https://www.laserleveloutlet.co.uk/
and in particular the Topcon RL-H5A mm/inch Kit: https://www.laserleveloutlet.co.uk/...-ls-100d-rotary-laser-level-with-tripod-staff
The Topcon RL-H5A is a full self levelling red beam rotary laser which levels on the horizontal and can do single grade off the keypad. It is accurate to ±1.5 mm at 30 m, a range of 800m and has an IP rating of IP66 (Dust tight / Protected against powerful jets of water).
The Topcon RL-H5A (mm/inch) Rotary Laser Level Kit comes configured with the LS-100D Detector (mm / inch scale) to see the elevation or drop on the display e.g 10mm - 8mm - 5mm - 2mm - LEVEL.
Outlet products are typically cheaper than normal retail versions because some items may have small cosmetic flaws that don’t affect functionality but keep them from being sold at full price.
Best regards
Mark Roberts
Canal Navvy
Canal Navvy
For those customers on here with Spectra Lasers, we have recently produced an updated Handy Tips & Advice guide which makes excellent bed time reading :D
You can check it out here:
https://www.laser-level.co.uk/pdfs/Spectra Handy Tips & Advice.pdf
This guide covers lots of the common "how to" questions we receive and how to get the best from your Laser kit.
Best regards
Mark Roberts
Laser Levels Online
I was expecting to see the "work around" for 90 degree sqaring....
... when I'm setting out I use mask mode on the unused segments and it then makes the static beam detectable with the receiver 😃
