kubota kx61/2
  • Thread starter Dougie Anderson
  • Start date
Dougie Anderson
Hello, looking for some advice regarding the boom on my Kubota kx61/2
i have changed rotary shaft bushes, emptied hydraulic oil from tank, put in new filters. Blade works will track but boom wont move. Can anyone help please?
cheers, Dougie.
cheers, Dougie.
are you referring to the rotary coupling down through the centre of the slew ring??
shouldn't have any effect on anything 'upstairs' :rolleyes:
It's not just the deadman lever solenoid or switch not engaging? Fairly sure the KX161-2 (5 tonner but same series) the tracks and blade worked regardless but only the boom was deactivated by the deadman...
good shout ... yeh blade and tracking is non servo .. boom, dipper, slew and bucket are all servo controlled functions
Youd need to check your getting pressure to the ram... could be a problem in the ram itself or the oil getting to it
diggerjones
diggerjones
Yeah my dash 2 is like that
What I was gonna say was change over the solenoids for pilot and fast track and if any hydraulics come back when you operate the fast track!
