Kubota KX015-4 Error code 025
A
adamr7747
Hi All,
My 1.5t Kubota is coming up with a "25" error code & flashing red warning triangle. If I turn the engine off & on again both disappear, but come on again after 20 or 30 minutes. I can't find any reference to it in the manual. Does anyone know what the code means & what I should do?
Thanks,
Adam
Couldn’t find a list of fault codes for Kubota excavators, but on Kubota tractors…worth a check?
A
adamr7747
Well, I found a list of codes in the manual - but they stop at 24 :confused: & then today I went to use the digger & it won't turn on 😧 Nothing even showing on the console, no noises, anything. I checked every fuse, including the 3 in the battery compartment & even tried jumping it, but it made no difference. Anyone know any other likely things I could check?
Thanks,
Adam
Thanks,
Adam
is it insured ? 🔥🔥🔥
