Kinshofer HPXdrive digging grapple
That would be big enough just looking the description is wrong 50kg or next size up 100 kg
Haner with rotator ... which'd cost you well over a grand
flog it on
someone's greedy/making a killing
bigger one
loads here - none cheap :(
sign up to Euros Kev
there're some here for comparisons ... open up the full quote for all of 'em or scroll up to my reply to Kev
Don't need a rotator but at those prices rekon you could buy new
mine from @Tintan28 was brand new on the original supplier's pallet cost me £1020 with 80 quid shipping and unavoidable VAT
he also saw 'em going for 200 quid a few weeks later at Euros -- just checked our various PM,s :oops:
JerryRtilt
JerryRtilt
I have this Dala Grippen DGS12 from @CPS, 62kg plus S40 bracket, opens to 835mm, worked fine with the Rototilt on the Zero swing Volvo, if you fancy tempImageKJboLU.png a deal, been thinking of going up a size to a DGS20 if Aiden could get one, now i have the 27 with a bit of tailswing could use something a bit larger, very well made Swedish quality £1450 new.
I have this Dala Grippen DGS12 from @CPS, 62kg plus S40 bracket, opens to 835mm, worked fine with the Rototilt on the Zero swing Volvo, if you fancyView attachment 50403 a deal, been thinking of going up a size to a DGS20 if Aiden could get one, now i have the 27 with a bit of tailswing could use something a bit larger, very well made Swedish quality £1450 new.
Dala Gripen stuff is very well made, fair play
Just guaging if this is of any interest to anyone before subjecting myself to Facebook😩.
Kinshofer grab. On 50mm pins. Very good condition. Ex EA since new and not sure what they've been doing with it as seems like barely any wear. I've used it for about 100hrs but it's not suitable for my work really.
£4500 plus vat. Might sound dear but it's half the price of a new one and doubt you'd find a tidier used one.
Looks a great bit of kit . Looks a similar size to mine which is making me wonder if I could fit a rotator under a 50mm pin craddle so I could change the top and use it on the 8tonner as well .
I was looking at the Hanner only if I can get it cheap.
At moment I'm not desperate for 1 as in middle of purchasing something else. I'll let you know if it changes
JerryRtilt
JerryRtilt
No problem I’m in no rush either 👍
the hitch I made for you should bolt straight to the top of the rotator and the bottom of the rotator should bolt to the HPX drive Vin ... the centres are 140 x 140 mm ... and that's the same HPX drive unit as far as I can see ... also looks like it has a bottom feed to the HPX spigot fittings
Going off what mtk sell refurbished painted ones with headstock to suit I think you’re a bit on the high side but for the right person with the right job locally may suit them. Think they’re about £8k new
Brightwells used to get a lot of ex-EA gear with virtually no use at all ...
thought I'd bought this at one of their Auctions, but turned out they'd knocked it down to a guy stood behind me ...
wasn't overly happy about it -- would've bid again if they'd been clearer :mad:
Yeah could be on the dear side tbh, I was quoted just shy of £9k for a new one so reckoned half the price for such a low wear one would be worth it for someone. Im not really desperate to sell so will see how it goes on Facebook- bloody nightmare selling on there at the best of times.- "can you deliver to Africa" etc😩
Bloody hell buddy , I didn't realise that the free hanging rotator would be the same as the fixed one . I thought that the fixed one would have to be a bigger unit . What do you think of my idea . Any issues with fixing the rotator under a 50mm cradle and then just swapping the cradles over to use on both machines ?
crossed wires here somewhere @Vinpetrol ... a free hanging rotator will likely snap in half if fixed solidly and loaded laterally/not vertically ... doesn't have the same sort of 'meat' and build.
I meant that Storrsy's fixed rotator could be bolted to your head plate ... a free hanger won't stand lateral loading ... only vertical loading
🤦‍♂️I thought as much . I moved my rotator yesterday and I thought it looked a bit small for that kind of set up . I need to keep an eye out for a fixed rotator then !
if you don't want to use the att., free hanging :rolleyes:
