Hg2702
It’s a wanted rather than selling but on the long shot does anyone have one of these they’d part with , new kitchen needs bastardising
Who eats toast after more than 30 seconds after it's out the toaster ffsWho the f**k uses a toast rack
Game onWhy waste the space with a f****ng toast rack when you can invest in a mechanical toast tap.
Commercial Conveyor Toaster 150 slices/hour | Adexa CT1
Commercial Conveyor Toaster 150 slices/hour | Adexa CT1adexa.co.uk
Posh builders … I’ll use it for putting my post into be fairWho the f**k uses a toast rack
Put your post straight in the toaster.., save worktop space!Posh builders … I’ll use it for putting my post into be fair
but only the bills ... then 'toast' 'emPut your post straight in the toaster.., save worktop space!
absolutely ... can't abide cold toast .... toaster...plate...butter...mouth ... less than 30 secondsWho eats toast after more than 30 seconds after it's out the toaster ffs
Any one over 80.Who the f**k uses a toast rack
And proper butter too. Salted ideally. Not this flora/Clover veggy grease. Have the cardiologist on standby when eating a piece of toastabsolutely ... can't abide cold toast .... toaster...plate...butter...mouth ... less than 30 seconds![]()
too right .. unsalted is like axle grease ..... as for the rest of that crapAnd proper butter too. Salted ideally. Not this flora/Clover veggy grease. Have the cardiologist on standby when eating a piece of toast
Throw back to youth that haha trying to push stuck toast off it between hot squares lol![]()
AGA Toaster
The unique AGA toaster, for use on the Boiling Plate to make toast as it should be, crisp on the outside, soft in the centre. This versatile product can also be used for toasting crumpets or teacakes and as a cake cooling rack.www.dissironworks.co.uk
Toaster made in this under the aga plate.![]()
used to have a 4 slot Dualit bun toaster in work .... was a great toaster ... 8 slices and swap faces .. eight slices ready in one go ... was great for feeding the 'team', breakfast timeWe’ve the 4 slice dualit acquired from somewhere like a job or sisters for free but doesn’t pop up so can over toast it a bit but does a good even toasting job. Just seen this 6 slice one though looks the muts nuts for 3 kids and wife needing buttery toast.
The toaster by which all others are judged...ours has a hard life must be years old now..We’ve the 4 slice dualit acquired from somewhere like a job or sisters for free but doesn’t pop up so can over toast it a bit but does a good even toasting job. Just seen this 6 slice one though looks the muts nuts for 3 kids and wife needing buttery toast.
