P
powercom
As the title would a 3 cx with extender /breaker pipework be suitable for a machine mounted vibrating plate ?
it will easily have the power to feed it but assuming that the return will be controlled by the spool valve and one the spool is switched off by letting go of the joystick mounted switch the vibrating plate would run on as its a motor driving offset weights and the oil have no where to go as the valve would be closed that I'm guessing is less than ideal
or does the bi directional hammer switch that some have in the cab change the extender circuit to feed and open return that I assume is more suitable for vibrating plate ?
