JCB 803 issues
C
Chevvy
Hi
I’ve just bought a jcb 803 1999 age ish.
The dipper ram array on going up or down until you touch the lever in the opposite direction. It then stops.
I’ve changed the valves, checked the levers and they’re all fine. Has anyone else had any issues like this before or could help steer me in the right direction.
Thanks
Hi
Thanks
summat's sticking ... if you've changed/checked the lever's valves it has to be the main slices :rolleyes:
C
Chevvy
Hi
Sorry I’m no expert by anymore means. What is the main slices ? Is this on the valve block ?
Where are the leaver valves located ?
Thanks
