Might be worth giving Vicary Plant Spares a try.
which'll be rocking about with the ring gear ..... I'd certainly have a good eyeball of itThe grease idea was just to give an indication of how bad it is, if I remember the slew ring on this machine contains steel balls and nylon spacers, without spacers because they have disintegrated, the steel balls aren’t evenly spaced and so it will rock about, filling it with grease would maybe give a bit more time and usage before having to change the ring, I doubt the slew motor pinion is worn as it drives on the fixed gear of the slew ring!
correction ... the ring gear will be stationary but the pinion'll be rocking about around the ring.which'll be rocking about with the ring gear ..... I'd certainly have a good eyeball of it
